  1. Do I burn a svcd with the "vcd-header-trick" as a vcd or a svcd??
    Nero is complaning either way I try..
    When I try svcd it says that the file is not the correct format and with vcd it says that it wants to convert the file...
  2. mmm...maybe your decoding setting was wrong...anyway let nero convert the file....
  3. oopps..tried the "search-buttom"..should have done that before posting,sorry
    The thing was to uncheck standard compliant vcd...
    Thanks anyway,wizzy
