I tried converting avi & mpeg files using TMGPEnc to mpg files, then used Nero to burn the mpg files as a VCD. When I play the VCD on a player, the video skips & audio is out of sync and gives a click clack sound the same sound when a cd skips. How do I solve this? Pls help me as I have already ruined 3 cds in this process.
Thanx.
N
When you use TMPGEnc, which template did you load, and is DirectShow at the proper priority?
Hello. -
I tried using my own template, i guess maybe thats y it wasnt wokring,
then i used VDub to separate the audio & re encoded using TMPGEnc using NTSC format. It worked finally, but I have a doubt whether if I dont use VDub & just use the NTSC format will it work? Seems like Nero likes the NTSC format made mpgs.
Video and audio out of sunc. - Audials one 9
By stonefox in forum Video ConversionReplies: 1Last Post: 24th Nov 2011, 04:59 -
How to add audio(.mp3) & adjust in video(.mkv) & burn in vbo ?
By ashe09 in forum AudioReplies: 0Last Post: 16th Jul 2011, 03:06 -
MPCHC Video Audio & Video playback Problems
By skorpinok in forum Software PlayingReplies: 11Last Post: 1st Jun 2011, 10:26 -
Matroska Video - Audio delay when skipping
By strutter_uk in forum Newbie / General discussionsReplies: 2Last Post: 15th Jan 2008, 11:08 -
audio skipping on video capture
By wan2no in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2007, 18:18
