Results 1 to 12 of 12
  1. I read somewhere that maxwell and apple are the most compatible media wit dvd....... i wanted to no a place where i can find the cheapest of each.... i havent even seen maxwell dvd-r....... can anyone help me out
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Apple disk are about the same price everywhere. Frys near me carries then if you have one around. (about $5 each in 5 packs)
    Mar 2002
    Hawaii
    Is Maxwell a brand? I've never heard of them.
  4. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Isn't it Maxell?
  5. can anyone else help me..... $5 is to much.... i ain ttryin to spend over $2 for the disk
  6. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    The disk I'm using are about 1x and $2.60ish each... so I dont know what to suggest.
  7. yea but is it a apple or a maxwell or maxell....???????
    Mar 2002
    Hawaii
    So there is a Maxwell brand?
  9. no.... sorry i gotta correct myself.... it is MAXELL..... i found out yesterday but they all still very expensive..... how so i find out if one of these companies put there dvd-rs out as no name at a lower rate like some other companies do
  10. we have maxwell vhs tapes in the land down under. ou might have been getting them mixed up.
    God created man and finding him not sufficiently alone, gave him a companion to make him feel his solitude more keenly. -- P. Valery
    Mar 2002
    Hawaii
    I'm not sure if it will work with DVDs, but there's a trick in Nero, that allows you to see the manufacturer of cds. Open up the medium info window and refresh it while holding "shift."
    Someone else on the forum posted a link to this.
    If it does work, you can buy a few cheap DVDRs and figure out which ones are manufactured by reliable companies.
  12. WELL..... i wll try that when i get home.... da only thing is tht i erased garbage ass nero off my machine when i found out that it dont do dvds well...... but hopefully it wll have some use this time
