I am having difficulty keeping the 16:9 ratio when I create a SVCD mpeg using tmpgenc.
Scenario:
- Using ATI All in wonder capture card, capturing from Dish a movie that is playing as 16:9 (source is not truely 16:9 right?)
- Using tmpgenc I have tried different settings and I can not get the output.mpg to keep the 16:9 "look", it turns into a 4:3 or 1:1 looks that way, If I burn to SVCD and play in DVD player 16:9 ratio is lost?
Can anyone provide some feedback here?
Thanks in advance.
Blahh.
AFAIK, the SVCD spec does not actually support 16:9 aspect ratio. The best you can achieve then is to encode at 4:3 and let your widescreen TV stretch it back to 16:9. Using the default TmpGenc template should be sufficient for this.
Originally Posted by Nico...
load up the movie in FitCD and it will tell you what to resize your svcd resolution to.
Then make sure the "source" is 16:9 and select "full screen: maintain aspect ratio"
MTS unable to play in WMP11/unable to edit in Movie Maker
By xxx4reggie in forum Newbie / General discussionsReplies: 6Last Post: 22nd Nov 2011, 23:04 -
Unable to create chapters while converting from AVI to DVD using DVDAuthor.
By sumit_pankaj in forum Authoring (DVD)Replies: 7Last Post: 11th Jun 2009, 01:40 -
[help] TMPGENC DVD AUTHORING v3 - unable to convert to MPG
By meeya in forum Authoring (DVD)Replies: 3Last Post: 19th Dec 2008, 04:47 -
Unable to burn DVD, unable to access the Video_TS.ifo.
By Asymmetry in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2008, 23:02 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 00:37
