I tried to download the vcdimager program. When I unzip the files there is no executable to install the program. I just wanna install the gnu program like in the manual. Can someone give me a direct link to get this program.
ok one last time. I just want to run the program like I see it in the manual. It is installed in vcdeasy i see. can I run it somehow from vcd easy. I just wanna see the gnu like in the manual
GNU = GNU's Not Unix.
If you do a quick Google search, you can read all about GNU.
I suppose that you actually mean GUI = graphical user interface.
VCDImager 0.7.12 is a command line program. As such, if you want to use it directly, you will have to load up the command console in WinXP. (Start --> Programs --> Accessories --> Command Prompt).
VCDImagerGUI refers to the GUI written by ?Baldrick available here: http://www.vcdhelp.com/vcdimagergui.htm This is based on the older version of VCDImager -- 0.6.x.
If you want to use a straight out GUI version of all the tools in VCDImager 0.7.12 (but not use VCDEasy or TSCV), then you could try VCDImager Tools GUI here: http://www.vcdimager.org/guides/vcdimager_tools_gui.html
Regards.Michael Tam
w: Morsels of Evidence
I would like to install Linux
By DVDONE in forum LinuxReplies: 2Last Post: 27th Apr 2010, 10:19 -
will not install
By ka3wjz in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 30th Jun 2009, 21:07 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43 -
Use without an install
By raschko in forum Newbie / General discussionsReplies: 0Last Post: 9th Aug 2007, 16:37 -
install
By Brasilman in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 29th May 2007, 09:17
