I'll try and be less confusing here now. I just want a player with good raw mpeg suppot. I've tried the apex 1100W. Its pretty good but has trouble with oddball resolutions. I want one that stretches to fullscreen regaurdless of the mpeg's resolution. Just a brand name or another apex model number would be a good starting point.
What I really need is a player that stretches raw mpeg-1 to fullscreen, regaurdless of funky resolution. Anybody??
There is none to my knowledge.Standalones play whatever resolution is on disk,it is up to your authoring software to set aspect ratio.
thanks. You may be on to something there though, tmpgenc does have the 'set aspect ratio' option that gets largely ignored. Unfortunetly, to my knowledge there is no tool to change this setting without re-encoding from scratch.
If anybody bothers to read this -- the Mintek 1600 I'm pleased to say, does to this quite nicely.
I have a Daewoo 4000S which I picked up at Target for $80.00 and to my surprise it does play any size mpeg that I have on a CDR.I can even scan forward & backward (but not more that about 2 or 4x). The picture does seem to fill the entire screen too.
How to properly multiplex raw mpeg-4 asp into an .avi container?
By Selur in forum Newbie / General discussionsReplies: 5Last Post: 8th Apr 2012, 11:09 -
muxing raw h264 with raw g711 to mp4 continer
By niror in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2011, 12:25 -
How to strip ip header from raw mpeg
By aj99v in forum Capturing and VCRReplies: 0Last Post: 11th Mar 2010, 14:54 -
Audio options in DVD player, RAW or PCM?
By dzsoul in forum DVD & Blu-ray PlayersReplies: 0Last Post: 31st Dec 2009, 06:00 -
Raw MTS files so good, and so small
By Priapism in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 28th Aug 2009, 01:20
