Hello Everybody...
I want to convert my old VHS PAL tapes to VCDs ... but until now my attempts was a disaster ... Let's see you experts can help me ...
I am using my Pinnacle DC10+ to create 640x480 AVI files, but when I convert to VCD, the quality is really bad ... I cannot see the eyes of people's faces ! I read something about Inverse Telecine (IVCT), but I wasn't able to do it ...![]()
Can you please send me some guidelines ?![]()
What are you using to convert your AVI file to MPEG-1? If you used TMPGEnc, did you use the VCD template from the Load function?
Hello. -
Hi Tommyknocker
Yep, I am using TMPGEnc, and the VCD template from the Load function. -
I once tried the DC30 from pinnacle (a friend of mine was selling it and he gave it to me to try - it's pretty similar to the DC10) and i was very dissapointed with the result. The reason - and i think is one of the reasons why your VCD's end up pretty bad - is that this card has onboard MJPEG compression (like the DC10). There is no way to capture uncompressed. Converting these highly compressed AVI's to MPEG didn't give a good result - for me at least. I get far better results just using my old PCTV card, capturing uncompressed and then converting with TMPEG. So maybe this is part of your problem too.
Jack
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
For VHS/S VHS tapes 10 - 20 years old what aspect ratio should I use 3:4 ?
By fuzzblaster in forum Capturing and VCRReplies: 1Last Post: 10th Sep 2010, 16:27 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 08:19
