Ok . Ive backed up a few films of recent using 5.1 sound films all pal .
I have some ntsc films.First 1 ive tried no sound.did a search on this forum tried downsampling to 44.1 ripped one chapter and still no sound.
Film oceans eleven region1 using dvd2svcd 1.0.9.build 3 same settings again but ticked ntsc to pal this works on stand alone dvd but no sound my dvd is only region 2(will Hack Maybe) so the ntsc to pal conversion works.
logs below
ISO MPEG Audio Subgroup Software Simulation Group
ISO 13818-3 MPEG-2 Audio Multichannel Encoder
Revision: 2.5 990316
>>> Using 3/2 configuration
Input file : C:\Program Files\DVD2SVCD\Movies2\Encoded_audio_1.aif
Output file : C:\Program Files\DVD2SVCD\Movies2\Encoded_audio_1.mpg
Layer : II Matrix mode : 0
Mode : stereo Center : 1
extn : 0 Surround : 2
Psac model : 3 Stereo : 2
Sample freq : 48.0 kHz Stereo mc : 3
MPEG1 bitrate : 128 kbps Stereo aug : 0
Multilingual : no multilingual coding De-emphasis : 0
Copyright bit : 0 Original : 0
Error protect : 1
-DEBUG: writting post-gap ('leadout pregap')...
INFO: finished ok, image created with 359422 sectors [79:52.22]
--DEBUG: EEL sysid=[C:\Program Files\DVD2SVCD\Movies2\VCDXBuild_Script_2.xml] pubid=[(null)]
--DEBUG: EEL sysid=[http://www.gnu.org/software/vcdimager/videocd.dtd] pubid=[-//GNU//DTD VideoCD//EN]
++ WARN: initializing libvcd 0.7.12 [cygwin/i686]
++ WARN:
++ WARN: this is the UNSTABLE development branch!
++ WARN: use only if you know what you are doing
++ WARN: see http://www.hvrlab.org/~hvr/vcdimager/ for more information
++ WARN:
--DEBUG: changed album id to `OCEANSELEVEN'
--DEBUG: changed volume number to 2
--DEBUG: changed volume count to 2
--DEBUG: changed restriction number to 0
--DEBUG: changing 'next volume use sequence 2' to 0
--DEBUG: changing 'next volume use lid 2' to 0
--DEBUG: changed volume label to `OCEANSELEVEN'
--DEBUG: changing 'relaxed aps' to 0
--DEBUG: changing 'update scan offsets' to 0
--DEBUG: adding pbc (chapter-01/2)
--DEBUG: adding pbc (chapter-02/2)
--DEBUG: adding pbc (chapter-03/2)
--DEBUG: adding pbc (chapter-04/2)
--DEBUG: adding pbc (chapter-05/2)
--DEBUG: adding pbc (chapter-06/2)
--DEBUG: adding pbc (chapter-07/2)
--DEBUG: adding pbc (chapter-08/2)
--DEBUG: adding pbc (chapter-09/2)
--DEBUG: adding pbc (chapter-10/2)
--DEBUG: adding pbc (chapter-11/2)
--DEBUG: adding pbc (chapter-12/2)
--DEBUG: adding pbc (chapter-13/2)
--DEBUG: adding pbc (chapter-14/2)
--DEBUG: adding pbc (chapter-15/2)
--DEBUG: adding pbc (chapter-16/2)
--DEBUG: adding pbc (chapter-17/2)
--DEBUG: adding pbc (chapter-18/2)
--DEBUG: adding pbc (chapter-19/2)
--DEBUG: adding pbc (end/3)
--DEBUG: sequence count 1
--DEBUG: adding sequence #0, C:\Program Files\DVD2SVCD\Movies2\bbMPEG_Muxed_File01.mpg
--DEBUG: pts start offset 0.220000 (max pts = 3416.092000)
--DEBUG: playing time 3415.872000
INFO: scanning mpeg sequence item #0 for scanpoints...
--DEBUG: already scanned... not rescanning
++ WARN: audio stream #0 has sampling frequency 48000 Hz (should be 44100 Hz)
--DEBUG: pbc: psd size 2968 (extended psd 0)
--DEBUG: iso9660: highest alloced sector is 246 (using 300 as isosize)
--DEBUG: requested entry point (id=entry-chapt-01) at 0.000000, closest possible entry point at 0.080000
--DEBUG: requested entry point (id=entry-chapt-02) at 62.800000, closest possible entry point at 62.800000
--DEBUG: requested entry point (id=entry-chapt-03) at 267.960000, closest possible entry point at 268.200000
--DEBUG: requested entry point (id=entry-chapt-04) at 392.600000, closest possible entry point at 392.560000
--DEBUG: requested entry point (id=entry-chapt-05) at 474.000000, closest possible entry point at 474.080000
--DEBUG: requested entry point (id=entry-chapt-06) at 650.640000, closest possible entry point at 650.600000
--DEBUG: requested entry point (id=entry-chapt-07) at 927.750000, closest possible entry point at 927.920000
--DEBUG: requested entry point (id=entry-chapt-08) at 1103.750000, closest possible entry point at 1103.840000
--DEBUG: requested entry point (id=entry-chapt-09) at 1282.630000, closest possible entry point at 1282.720000
--DEBUG: requested entry point (id=entry-chapt-10) at 1459.480000, closest possible entry point at 1459.480000
--DEBUG: requested entry point (id=entry-chapt-11) at 1610.000000, closest possible entry point at 1610.080000
--DEBUG: requested entry point (id=entry-chapt-12) at 1861.710000, closest possible entry point at 1861.880000
--DEBUG: requested entry point (id=entry-chapt-13) at 2081.040000, closest possible entry point at 2081.280000
--DEBUG: requested entry point (id=entry-chapt-14) at 2201.080000, closest possible entry point at 2200.920000
--DEBUG: requested entry point (id=entry-chapt-15) at 2419.960000, closest possible entry point at 2419.760000
--DEBUG: requested entry point (id=entry-chapt-16) at 2550.360000, closest possible entry point at 2550.480000
--DEBUG: requested entry point (id=entry-chapt-17) at 2701.550000, closest possible entry point at 2701.800000
--DEBUG: requested entry point (id=entry-chapt-18) at 2991.590000, closest possible entry point at 2991.720000
--DEBUG: requested entry point (id=entry-chapt-19) at 3127.480000, closest possible entry point at 3127.440000
++ WARN: generated image (357789 sectors [79:30.39]) may not fit on 74min CDRs (333000 sectors)
--DEBUG: OGT streams available: 0 0 0 0
INFO: writing track 1 (ISO9660)...
INFO: writing file `EXTRA/DVD2SVCD.XML' (20379 bytes)
INFO: writing file `EXTRA/SVCDINFO.TXT' (2040 bytes)
INFO: writing track 2, MPEG2, PAL 2/3 D-1 (480x576/25fps), audio[0]: l2/48.0kHz/128kbps/stereo ...
--DEBUG: MPEG packet statistics: 333352 video, 23836 audio, 0 zero, 0 ogt, 1 unknown
--DEBUG: writting post-gap ('leadout pregap')...
INFO: finished ok, image created with 357789 sectors [79:30.39]
Results 1 to 1 of 1
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 20:20 -
Lost Audio i think
By oz_surfer in forum AudioReplies: 2Last Post: 14th Jun 2010, 10:04 -
lost audio after effects vers 6
By santolina in forum EditingReplies: 2Last Post: 26th Jul 2009, 07:05 -
Once Again, VirtualDubMod Has Lost My Audio Decompressor
By Mitchum22 in forum AudioReplies: 2Last Post: 29th Jan 2009, 06:55 -
lost audio
By chelseamick in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 10:54
