  1. I encoded MPEG2 file to create a DVD, the file was in 352x576, wich is a legal DVD resolution. In the CCE setting tab, I checked 'DVD Compliant' and encoded the file, then, when I opened it, I've noticed that the file was resized to 720x576.
    I want to encode the file in the original resolution but don't know if I can safely uncheck the option, so, is this option really needed? and if it is, is there an option to change the resolution?
    Austria
    Try DVD2SVCd with cce encoder.
    when making, a 352x576 resolution mpeg2 stream, i think you dont need to check the DVD compliant.
    When using 720x576 "DVD compliant" is recomerd!!!!
    AMD XP2000,ASUSA7V333.GF3 V8200 TI200,
    Alpha 8045,Y.S Tec Poer Fan, Seagate Baracuda IV
  3. Member DJRumpy's Avatar
    Dallas, Texas
    You don't have to use that setting. If your encoding a video that is not Full D1 resolution *(720x480 or 720x576), leave it unchecked. As you have already found, leaving it checked will only cause CCE to resize your video to full D1 resolutions.
    Impossible to see the future is. The Dark Side clouds everything...
