Is it better than TMPGEnc and I heard that you need Adobe Photoshop 7.0 for it to work..is that true ??
Also how do I make my Side picuture bigger ? It's too small to view ..
I have both, and have never used them yet.
You can contact me if you need them
Maybe he meant ADOBE PREMIERE 6.0 which uses it???
In any case....I have all of the above....I share
You know why I was asking genius because when I tried to open it it woulrdn't saying something about Adobe that';s why I was asking...and I think it is Adobe Premiere..I have it anyway I was just asking whether or not to switch from TMPGEnc to Panasonic
I have the standalone version and its a lot better than TMPGenc for VCD's. Although it is a bit of a pain to use. Never managed to get the plugin to work with ANY host application.
Try the DVDx1.7 version with the panasonic plugin 2.5, this works every time, i try it.
panasonic mpeg 1 encoder vs. tmpgenc
i mean that the panasonic pruduce smoother pictures, and you get less macro blocks, than with tmpgenc.but tmpgenc produce the sharper pictures and more details.
My favorite is panasonic, because i dont want to see, too much macro blocks, but havent tested the new tmpgenc 2.58 version yet.
The last verion on my pc, is currently tmpgenc 2.53.xx plus
AMD XP2000,ASUSA7V333.GF3 V8200 TI200,
Alpha 8045,Y.S Tec Poer Fan, Seagate Baracuda IV -
So TMPGEnc doesn't get rid of Macro Blocks that good..you know Ive noticed that in the New 2.58 Version...I thought it was just the file..Thanks for the info...
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
What is the BEST Mpeg 2 Encoder Today?
By jrodefeld in forum Video ConversionReplies: 43Last Post: 2nd Jul 2011, 15:28 -
which mpeg-2 encoder would you choose...
By deadrats in forum Video ConversionReplies: 28Last Post: 12th Nov 2009, 22:11 -
Need Help Panasonic HDC-HS250P (AVCHD), USB to Windows Media Encoder
By planet_bill in forum Video Streaming DownloadingReplies: 1Last Post: 13th Aug 2009, 14:40 -
mpeg encoder for DSP
By mourya in forum ProgrammingReplies: 2Last Post: 31st Oct 2008, 11:28
