I have this 50KB picture file that I want to appear next to my name...but it says that the picture cannot be bigger than 6KBs how do I make it 6KBs
I also have Adobe Photoshop 7.0...
Heres how I did it, I use a package thats called 20/20. But it will work in any photo editor. Reduce the dimensions to 80*80 pixils and encode it to GIF. Should bring the size to 6KB it did for my pic. This one i use was 320*240.
A bird in the hand is worth a foot in the tush-Kelly Bundy -
wait how the hell did you fit those DImensions..it says that the picture can not be bigger than 80 Pixels..and my picture is 236 X 600..what should I resize it too..?
In photoshop, hit ctrl+shift+alt+w. This will open a window that allows you to redimension and choose a new format.
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 01:06 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 04:52 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 16:41 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00 -
How do I capture a picture frame from a movie and make it into a picture?
By Hawkredtail in forum Capturing and VCRReplies: 7Last Post: 8th Sep 2007, 18:44
