I am thinking about getting a G4 w/ FCP and a Cinewave option ...
any advice or thoughts or even "you are stupid and buy this instead"
I will possabily getting a DigitalVoodoo sdi 10bit capture card also - maybe
it will be used for composition, color correcting and formating for dvd - and wish for 10 bit I/O - which is pretty hard to get on NT
as i have already a Fusion set up on NT and a Shake setup on SGI for HD
Since no pros have responded, I'll offer what little I have to say.
I can't speak on any capture cards, but for color correction and other adjustments FCP is fantastic. The tight integration with DVD studio pro makes it very easy to lay out the disc however you want. It is very easy to make your DVD and footage just how you want it. I am an amateur, and I used a couple different cameras for a friend's wedding. Mine was a canon, and the others were analog. I captured to digital tape before edition. The color and sharpness were way off from each other, but after using FCP they look identical.
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 06:04 -
Hauppauge HDPVR on a Mac using HDPVRCapture (or EyeTV) into FCP questions
By sinceyoudied in forum Video ConversionReplies: 0Last Post: 25th Aug 2010, 11:17 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 06:18 -
HD capture with Mac G5 FCP 5
By artvesta in forum Capturing and VCRReplies: 4Last Post: 12th Jun 2009, 17:54 -
Capture DV with PC/Edit on Mac with FCP????
By mkoplin in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2008, 20:33
