Hello All
this is my first post and hopefully im going to be doing a lot of copying to vcd in the future
i have a lot of hi8 camcorder footage and i am hoping to covert it to pal for my parents (back in england as i now live in the usa)
the only thing is my camcorder is only hi8 so i have no way to transfer digital video the only thing i can come up with so far is maybe something like the usb capture devices and transfer that to my pc and then do the convertion
is this going to be ok? i know these devices dont have amazing quality but if i could get a idea if its going to be ok then i can go ahead and try and fing the best capture device or would i be better off just sending them away and paying to have them converted to pal vhs?
any help is appreciated
best wishes
Adam
Digital 8 camcorders will export Video 8 and Hi 8 footage via DV-out. This is your best option, but you will need a new camcorder and a firewire card.
This is how I exported my Video 8 material. I don't know the best options for analogue output, but I suspect usb options may not be fast enough for good quality.
i would suggest a firewire capture card if you can afford to spend a little more .
ADVC-100 Media Converter is an excellent solution .. -
A firewire card would be a useful addition, and cost ~ £30/$50, but you still need a digital input, or something like Dazzle's DV bridge (which will allow analogue input through a firewire card). I presume the ADVC-100 Media Converter is a similar device?
yes -- it is an analog to DV transcoder http://www.sharbor.com/products/CANN5010002.htmlOriginally Posted by banjazzer
Converting PAL to NTSC?
By Djehuty in forum Video ConversionReplies: 17Last Post: 3rd Sep 2011, 14:55 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
Converting NTSC-PAL
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 10:06 -
Converting 30P to PAL
By EdgarPitts in forum Authoring (DVD)Replies: 5Last Post: 21st Oct 2007, 06:38 -
Converting PAL to DivX
By didikai in forum Newbie / General discussionsReplies: 2Last Post: 5th Aug 2007, 20:27
