DVD coded in MPEG-2 format with build-in Premiere 6.5 codec does not work well in my stand alone DVD player (Pioneer DV-444). The DVD stucks for 0.5 seconds occasionally. If I code to MPEG-2 format with TMPGEnc, it works fluidly, without stucks and pauses.
I want to use Premiere 6.5 codec because it gives far better picture quality than TMPGEnc. Do you know where is the problem with build in MPEG-2 codec in Premiere 6.5?
Thanks...
Looks like you are on your own: works fine for me and couple of my friend, who have different DVD players. Try reinstalling Adobe. -
I am using default settings for DVD. Plus I am using multiplexing. What is your GOP structure when works? Mine is BBIBBPBBPBBPBB...
i suspect your bit rate is to high ...
also the adobe built in decoder defaults to motion blur -- way to much .. i would turn it off ... not that that is your problem .. -
The bit rate is not too high because it is coded on 6 Mbit/s like on TMPGEnc and video coded with TMPGEnc is working. The video with built in Premiere codec does not work...
PAL coded DVD in U.S. player?
By Goodluck Jonathan in forum Newbie / General discussionsReplies: 50Last Post: 16th Apr 2012, 23:27 -
Anything Adobe Premiere 5.1 does that Vegas Pro 8 doesn't?
By brassplyer in forum Newbie / General discussionsReplies: 5Last Post: 10th Jan 2012, 01:04 -
Audacity doesn't load wav from Premiere
By Instant Martian in forum AudioReplies: 2Last Post: 12th Jun 2010, 10:26 -
VirtualDub doesn't see x264 codec.
By olegk in forum Video ConversionReplies: 7Last Post: 9th Jun 2010, 02:10 -
Premiere Pro CS3, MPEG2 to DVD, which field first?
By trikcard in forum Video ConversionReplies: 3Last Post: 18th Sep 2007, 23:29
