Hey does anyone know of a utility that will allow me to see if a VCD is either in PAL or NTSC format? (ie view the frame rate it is envoded in)
Thx
Results 1 to 9 of 9
Virtual Dub is your best bet. There are other apps but you will
find that if you stick to VCD/SVCD work, Virtual dub will become useful
for other things as well.
http://www.virtualdub.org/
..or you could right click on the .DAT video file, choose open with
media player2, right click on File and choose properties, mpeg. -
I tried the mpeg properties program... it works fine with mpeg files, but when I try and open a dat file (from a VCD) it does not show me any of the video info, only the audio info.
Any idea what is wrong? -
This happens when the dat file is on a CD rather than your HD. You can extract the dat (or a small portion of the dat) using Isobuster. Then it works properly.
If you place a shortcut to MpegProperties in C:\Windows\SendTo you can then have access by right-clicking on an mpeg/dat.
ok, thats good... but is there no way to quickly get the info. I did not really want to have to extract the mpg just to check the frame rate....
Also, I tried VirtualDub and it works fine but kind of has the same issue. It has to churn through the entire mpg before showing the info.
Is there any quicker way of doing this that you guys know of?
Thanks for the help... -
You only need to extra a tiny fragment of the mpeg!but is there no way to quickly get the info. I did not really want to have to extract the mpg just to check the frame rate....
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 18:59 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
