help, im trying to backup a disney film and the sound is out -80ms, spruce up will not import the file as it sais that it is inconsistant...ive tried to use ac3 delay corrector,but it sais source file damaged and ive tried to re-incode it with be sweet but the file is comming up alot smaller and when i try to import it in spruce up it sais media detection error, can some1 please advise me on this matter
SneakyG
-Girls best friend- -
i take it you ripped a dvd and ended up with a ac3 file with a long name and part of that name is 80ms delay ..
well first - rename the file to dos conventions (8.3 naming )
then rename your video stream the same except for the file exten.
import those into spruceup ...
ac3 files from disney have timecode inthe ac3 file and will lock to the video (in spruce maestro anway, i suspect in spruce up also)
if your ac3 file is damaged - you should re-rip it .. -
BJ_M i have renamed the file so that they have both (the video and sound) have same name, but it imports about 99% and sais inconsistant bitrates, im not sure how to get around this, any ither ideas?
SneakyG
it is because the menu and credits have different bit rates .. since it says it at the end it may be just the credits OR may be just the very end ..
you will have to rip by chapter or edit the ac3 stream or re-encode the ac3 stream completly (not suggested) ..
you can edit the ac3 stream with vitec dvd tools - but it may be easier for you to rip credits out ..
if it is just the VERY end -- use a file cut tool and cut the end of the ac3 file - last 1k is good start. you can accually do this with winrar if you dont have a file editor ... Split files - store only (no compression) .. rename part one back to origanal - throw away part 2 ..
the audio can be shorter than the video stream -- no big deal -
if you had Maestro you can make a ac3 sync track (writes a new ac3 file) -- which may get around the problem also ...
Problems importing ac3 in Vegas Pro
By mltwitz in forum AudioReplies: 0Last Post: 12th Jun 2010, 13:55 -
dts to ac3 problems
By scarlac in forum AudioReplies: 5Last Post: 23rd Apr 2010, 03:41 -
Windows 7 AC3 Problems
By eon_designs in forum Video ConversionReplies: 3Last Post: 20th Apr 2010, 05:07 -
Ac3 Downsampling problems
By robbynaish in forum AudioReplies: 1Last Post: 27th Jan 2010, 18:33 -
Problems encoding from Vegas to Divx and AC3
By grendizer in forum Video ConversionReplies: 0Last Post: 6th May 2008, 05:30
