can it be done?
i have an avi file that is like 2:30 hours runtime i was wondering if i can put this on 1 cd as a vcd.
it was in yuv2 format with compression i think 322 x 250 or somehng to that effect. 44100 16 bit stereo thru virtualdub.
No you can't. You can only fit about 80 min VCD on a 80 min CD, www.vcdhelp.com/vcd . If you want it on one CD you have to make xvcd,xsvcd or svcd but 2.30 hrs is a bit too much even for that http://www.vcdhelp.com/forum/userguides/84759.php .
If you don't need it to work on standalone dvd players you could fit it one cd using divx with decent quality. -
so i guess if i want it in highest quality like i captured, i would wanna burn it to 2 cd's, huh?
using the tutorial i found on your site?
Need to burn 24Gb video file to many DVD5's
By alegator in forum Newbie / General discussionsReplies: 11Last Post: 10th Aug 2010, 13:20 -
AVI to VCD
By Slip Kid in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 01:40 -
avi to vcd
By cornick in forum Video ConversionReplies: 4Last Post: 11th Aug 2008, 21:12 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
