I just bought my ATI All-In-Wonder 128 Pro last week and when I tried capturing my NTSC tapes, the video has no color. I found out that the system of my AIW was PAL. Is there any way I can capture my NTSC tapes with it's true color? Please help. I don't want my money wasted on this.
It sounds like you are trying to capture with composite output from your NTSC VCR player. If you are, try capturing the analog (RCA) output instead. Good luck!
Hello. -
Tommy...I am getting my output from the VCR via RCA cable. My VCR is multi-system. I guess there is no problem with my player but the card. My AIW is PAL system and just like TV, if you play an NTSC tapes to your PAL TV, you will not see the correct color (more of a black and white video). So, is there any way I can capture my NTSC tapes on my PAL AIW?
i don't know what the other post was talking about, composite video (for all intents and purposes) IS the RCA video output.
go into ATI MMC setup, and under "tuner" tab, change "cable standard" to "United States", and that should set you up for NTSC. some of the actual tuners have both crystals to tune NTSC and PAL, but if you don't have one of those, you can still caputre composite or s-video in either format, since the rage theater chip, not the tuner, takes care of that. -
Guys, thanks for all the help. I was able to play my NTSC tapes on my AIW by using my VCR's function 'NTSC Playback on PAL TV'. I found the switch at the back and when I turned it on, the video shows the correct color on my AIW. Thanks again!
Capturing NTSC tapes on PAL VHS and DVR
By ramrod1234 in forum Capturing and VCRReplies: 0Last Post: 23rd Oct 2009, 22:08 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 16:36 -
Capturing NTSC VHS tapes to PAL Final Cut...
By willed in forum Capturing and VCRReplies: 2Last Post: 22nd Jan 2008, 17:48
