I know theres a guide on the site that gives a method on how to do it without 8GB free, but it doesn't actually say how much space I would need.
I'm wanting to rip DVDs of variable length (from 20 min anime episodes up to 3 hour movies)... is it possible to do a high quality rip and convert to (S)VCD with such little HDD space? if so, mind pointing me in the direction of an applicable guide?
EDIT: A bit more info on my system:
I have a 266Mhz CPU, and a LiteOn 40125S CD-RW. Haven't got a DVD-ROM yet, but I will very soon, providing I am able to do these rips. 64MB of RAM, using Win98SE.
Oh also, if it is possible, how much space would I need (bearing in mind I already have space used on the drive, so I don't exactly have 4.3GB in free space)
DVDx will rip directly to VCD or SVCD, so yes, you *should* be able to do it.
Will the quality by just as good as if I did a proper DVD Rip (i.e rip to HDD first then encode to (S)VCD?) Coz I was thinking of getting a new HDD anyway... and if a proper rip will allow better quality, I guess I will get one.
I wouldn't recommend ripping direct from a dvd drive unless you want to shorten its lifespan.
Buy a decent hard drive and rip to that first.
Mike -
Originally Posted by mickle
hard drive is the best option (for me, using dvd2svcd and cce) -
DVDx (although not the best option), has an option to buffer the DVD output to either RAM or HD thus saving ware and tare on your DVD drive...
I ddi read in the guide its bad for your HDD... but why? It said something about it being constantly accessed (I assume that means constantly being read from while ripping) so how is that different to playing back a movie in the drive? If you do that the laser is constantly reading the disc.
Anyone able to clarify?
Bluray mainmovie rip to HDD, becomes more than one file?
By bagmand22 in forum Authoring (Blu-ray)Replies: 0Last Post: 12th Oct 2010, 06:20 -
Software to rip my DVD, BD, HD collection to my HDD and use tver**ty?
By djc347 in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2009, 03:01 -
AVI to DVD - Only 3Gb size
By Mutenroy in forum ffmpegX general discussionReplies: 3Last Post: 28th Mar 2008, 23:39 -
1.3GB DVD Help Camcorder
By Mark V in forum MacReplies: 8Last Post: 18th Sep 2007, 11:24 -
Converting AVI to DVD - Only 3Gb
By Mutenroy in forum ffmpegX general discussionReplies: 4Last Post: 2nd Aug 2007, 17:21
