I can't find a software that will open or edit these files.
I'm afraid to create movies in SVCD due to the fact that only my DVD/VCD player is able to play the movie.
I tried many mpeg2 editing softwares and they have no luck opening the file. Most or all of them claims the the file is invalid.
So, if anybody knows of a name of a software that can edit these mpeg files, please tell me.
Closed Thread
After they are in SVCD format...they should still be mpeg2...however, the file extension is .dat
Most of the time, you can just change the extension from .dat to .mpg. Otherwise, you would need to extract the video first.
You are in breach of the forum rules and are being issued with a formal warning. Stop morgue diving posts that are 4 years old.
/ Moderator lordsmurfGoogle is your Friend
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Nero InfoTool mis-identifying MPEG2 as MPEG1?
By justin81 in forum Newbie / General discussionsReplies: 0Last Post: 21st Mar 2008, 10:00 -
Combining Sony mpeg2 files with m2ts files
By hsid in forum EditingReplies: 8Last Post: 2nd Mar 2008, 20:51 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 12:03 -
Burning mpeg2 to DVD-9 with nero 6
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 03:11
