i want to broadcast with aiw radeon
windows media encoder 7.1 recongnize my card
(rage theater ) but failed to start encoding
( some driver fault....)
also i would like ati capture to be recognise as web-cam
( my real web-cam work with media7.1 encoder)
somebody can help me
thanks
try running the capture program that comes wiht windows media encoder... don't actually capoture anything, just run it, then run the media encoder/server program and start a session. It is a known bug and a known workaround
wcb4
check this out
http://www.ati.com/support/infobase/3692.html -
wow thanks very much
i almost find that ,but never be able to find the
necesary application on windows jungle !
there is almost 10 possibility of download
with directx sdk , some are 300 meg !
the "amcap" specific .exe file is hard to find
can you point me to the specific download file
or send me the file (freeware=ok)
cbya29@hotmail.com
thanks again -
also , forget to mention
i use win98se
i have amd athlon 1.2 gig
system is optimize for capture
( mmc svcd or dvd without frame drop )
try to broadcast with win,media 7.1
i first open wmcap.exe that came with
media 4.1 tool kit and did not start capture
than try to broadcast , stil not work
( system freeze )
or other apps. stil dont recognize the capture device
( web-cam apps )
thanks for help
gg
How to stream/broadcast live TV using Star Media Center
By Baldrick in forum User guidesReplies: 17Last Post: 27th Jun 2015, 11:49 -
How to broadcast a live satellite TV by Adobe Flash Media Live Encoder
By mrweb in forum Video Streaming DownloadingReplies: 0Last Post: 19th Aug 2010, 20:08 -
recording and broadcast live video
By George2 in forum Newbie / General discussionsReplies: 2Last Post: 1st Jul 2009, 10:57 -
Broadcast live helmet cam video to a TV
By phisherman11 in forum Portable VideoReplies: 1Last Post: 20th Aug 2008, 14:57 -
Using ADS TECH DVDXPRESS 2 to broadcast live
By KenshinGoku in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2008, 08:24
