hai guys
i need to know how to do this as VCD's otherwise i prefer svcd for its quality.( i liked johan vcd builder a lot but currently he informs his application could not do menu..very helpful guy he is)
see i have a ( photoshop ) menu which has 4 buttons..FILM 1 FILM 2 FILM 3 & PLAY ALL..
i would like the film 1 to play when the user click it withmouse or with remote & all film
in the order of 1-2-3 should play when they select PLAY ALL..can you pl guide me
pr is there any way to select the film so that that alone will play with PLAY OPTION which should play all sequence..
note: in pc these are really easy.but in mac..oh gosh !!!!
thanks 4 inputs
sreni
Help in nested menu based video cd
By khankadir in forum Authoring (VCD/SVCD)Replies: 2Last Post: 17th Sep 2011, 14:18 -
HELP with Sony DVDArch5 & burning a menu-based Blu-ray... successfully
By jimcornetet in forum Authoring (Blu-ray)Replies: 4Last Post: 20th Jun 2010, 11:14 -
Dye-based vs metal-based: which will last longer?
By RedZone in forum Authoring (Blu-ray)Replies: 11Last Post: 11th May 2010, 21:30 -
Author AVCHD with simple text-based menu?
By litmus in forum Authoring (Blu-ray)Replies: 1Last Post: 28th Feb 2010, 17:52 -
Creating Menu Based Blue Ray with HD & SD footage
By RaV4MaN in forum Authoring (Blu-ray)Replies: 7Last Post: 5th Jun 2009, 20:46
