I borrowed a friend's Cannon GL1 to tape a wedding for a friend's daughter. The Camera was in the 16:9 mode for widescreen Tv and now I have a tape that looks like the wedding of the tall people. The bride and groom don't have wide tv. Is there anyway to convert tape to 4:3 for regular tv. I know that this would probably take a computer and software. I have a friend with a new imac with a superdrive(DVD-R), but I think the only program he has is imovie2. Any suggestions would be greatly appreciated (with reasonable cost).
Go to here: http://pages.infinit.net/mannyp/imovie.html. Click on "using 16:9 footage". This is exactly what you are looking for.
Personally, I would use DVD studio pro and apple's encoder. Then you could check the 16:9 box, and set up your dvd to display it correctly. Easy.
Jeremy -
If you just wanted to burn a VCD/SVCD/CVD with it, TMPGenc will convert it no problem. Just set the input AR to 16:9 and the output AR to fullscreen (keep aspect ratio 2).
This is the MAC forum!Originally Posted by energy80s
There is a new plugin for iMovie that allows you to convert 16:9 to 4:3 and back again. It is Virtix 16x9 Converter. Check it out at www.virtix.com. -
Sorry, I don't look in the forums just in the latest posts. Like 90 odd perecnt of the population, I don't use a mac so can't help you out.
That is so annoying.Originally Posted by tgpo
I need to start posting about Mac programs in the PC forums. :P
For the love of God...Ripping disaster
By GwnLee in forum Authoring (DVD)Replies: 3Last Post: 13th Sep 2011, 18:51 -
Power failure = disaster, any way to salvage?
By PhillT in forum Newbie / General discussionsReplies: 14Last Post: 18th Apr 2011, 02:16 -
Question about Disaster after using Partition Magic
By jimdagys in forum ComputerReplies: 9Last Post: 20th Nov 2009, 12:22 -
JVC S-VHS machine w/ stabilizer "on" plus inline TBC = disaster?
By justin81 in forum RestorationReplies: 8Last Post: 7th Oct 2009, 01:23 -
Disaster Has Struck: Problems w QT update to 7.2.0 player 7.2
By rotuts in forum MacReplies: 4Last Post: 2nd Aug 2007, 06:23
