i'll just b sitting here n i'll here that booobeep sound which is usually played when u unplug a device, now i'm trying 2 rip some stuff and after about 10 minutes it stops and a box pops up saying the DV device is blah blah not able 2 control cuz it seems 2 have put itself to sleep...then when i unplug the firewire plug from it and plug it back in..it beeps....its fine and ready 2 go again..what the hell is the deal?![]()
What kind of Firewire card are you using? My DV-Bridge sometimes disappears, but usually only after a much longer time period than you seem to be experiencing , and it comes back after unpowering it and repowering the DV-bridge. Occasionally, my system loses its Firewire capability and I have to reinstall the Audigy software.
What OS are you using and how current are the Firewire drivers for your card? I don't have much idea what might be the problem, but maybe the additional info will catch some's attention. -
I'm using XP pro w/ SP1 and i'm using the card that came w/ the DV-bridge
c it doesn't vanish when it disables itself...its still there but u can't control it unless u unplug it then plug it back in..... -
Does nebody know what card came w/ the DV-Bridge? I don't have the box, threw it away
Mine looks like it says Indigita Corp. IDT 481 PCI.
I don't use it, my machine has onboard firewire. And I don't have your problem. The DV bridge does mess up the machine if I boot with the bridge connected, but that is easy to solve. Just connect after booting.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Odd Recording Volume Problem
By blewyn in forum AudioReplies: 5Last Post: 10th Feb 2013, 13:27 -
Ivy Bridge to be up to 199% faster than Sandy Bridge
By deadrats in forum ComputerReplies: 33Last Post: 7th Dec 2011, 13:06 -
Hauppauge 150: Another Odd Problem
By Tom Saurus in forum Capturing and VCRReplies: 0Last Post: 12th Jun 2010, 12:22 -
Odd ac3 sync problem
By mayancastle in forum DVD RippingReplies: 7Last Post: 24th Jun 2009, 22:34 -
Odd problem? dv video disappears
By phorkster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 17th Sep 2008, 07:57
