Hi,
I am in process of authoring a VCD with menues. I used mpeg tools to generate still mpeg for my menu. The resulting mpg file looks good as the original bmp image itself. However, when I make the final vcd, the menu looks pretty bad - not crisp at all - all fuzzy and not sharp.
It also seems like using "Nearest" algorithm for resizing instead of "Spline" makes it better. But still not good enough. Also, if I use anything but "Spline", I get an issue with my software VCD player where while in the menu screen turns solid green color and doesn't refresh back , until the actual video is played.
Any idea how to make it look good?
Thanks.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Most of the MPEG codec on PCs do not decode correctly MPEG Stills. The one provided with PowerDVD 4 seems to be ok.
So, to judge the quality of the MPEG Stills, better use the home DVD player. Now, if you have bad display on the home DVD player, you can try to use the more recent MJPEG Tools (1.6.0rc2) available in the "beta version" page at www.vcdeasy.orgdelphi.stuff, VCDEasy author
http://www.vcdeasy.org -
Originally Posted by delphi.stuff
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
How to keep subtitle text from looking ragged in final disc image???!!
By wildgeese in forum ffmpegX general discussionReplies: 8Last Post: 24th Feb 2009, 14:40 -
fixing bad sectors/Toast disk image
By danielmak in forum MacReplies: 6Last Post: 26th Jun 2008, 05:35 -
Hopefully my final Acronis True Image question.. .
By Denvers Dawgs in forum ComputerReplies: 6Last Post: 26th Jan 2008, 10:34
