  1. I got through DVD2AVI ok and I ended up with 2 files, a .d2v and .wav
    I go to TMPGEnc and following Sefy's guide I end up with only 1 .mpg file. According to that though you need two (I'm guessing 1 fits exactly on the CD and the second is what's left.)
    This makes going through VCDEasy fail because I have only one file and it is of course two big.
    If I have indeed got the DVD2AVI step correct, can someone please post here or send me an email (tilbrooka@yahoo.com) as to what how I go through TMPGEnc properly and then VCDEasy.
    Any help very much appreaciated!!
  2. Please can someone help?
  3. please wait at least a day or so before 'bumping' your post.
    thanks. This is the 2nd time you have done this.
  4. you can split the mpeg into 2 mpegs using the mpeg tools facillity in tmpgenc .
    as long as the mpeg is no bigger than 800meg it should fit onto 1 80min cdr.
