  1. Suggestons for a UK DVD Player please
    Would like it multi Region and Macro disabled.
    Must be able to play as many formats as possible, eg
    VCD/SVCD/MP3/DVD-R etc etc.
    Budget = max £120.00 - any recommendations please.
    Thanx
  2. http://www.scan.co.uk/products/ Scan SC-2500 DVD player Multiregion PAL/ NTSC/ MP3 /Onboard Dolby/dts out
    £98.00 ex. VAT
    £115.15 inc. VAT
    SC2500 DVD Player
    Dual Decoding : Dolby Digital (AC-3) & DTS decoding.
    Compatible to DVD, CD, VCD, SVCD, CD-R &CD-RW, and MP3 discs.
    Dolby Pro Logic processing.
    Built-in six channel 96K/24-BIT audio DAC.
    Video outputs: Composite Video and S-Video .
    Audio outputs: 5.1 CH, 2 CH, Optical and Coaxial digital output.
    Supports system conversion: NTSC to PAL and PAL to NTSC.
    Colour: Black.
    Main Features:
    24-bit PCM Digital Output Capability
    10-bit Video D/A Converter
    Automatically identifies the disc
    Timer and auto power off
    Memory Playback
    Time search playback
    Program Playback.
    Selectable OSD
    Picture enhanced
    Zoom panning
    Screen saver
    Remote control
    This is what I went for and I have no probs with it - ordered it 11pm one night had it by 12.00 noon next day
    Hope this helps
    fudgey65
  3. Banned
    Jun 2001
    UK
    Check "Big W" if you have a store near you, or Safeway, Sainsbury, less than £70 for playback of everything
