  1. I am using Ulead DVD Workshop 1.00 to make my vcd menu, everything works fine but for the menu i need to press the number of the video track to play it, how do i make it so that i can just selected using the arrows/clicking on it.........
    thanx
  2. or anyone know a program that makes vcd menu's Better than Ulead dvd workshop for vcd's with songs in the background and interactive menu's............
    svcds and vcds dont support using the up down arrows like a dvd.
    Australia
    I make motion menus for my VCDs in Photodraw 2000. I resize the canvas to PAL VCD res (352x288) and make each individual frame, saving each as a .bmp. Then I use bmp2avi to combine them into an avi file. With that I encode it into PAL VCD in TMPGEnc and (if applicable) mutliplex an audio track into it. Then I use VCDEasy to make my VCD image, and burn with Nero.
    If you are prepared to dedicate the time into making frame-by-frame menus in a program like psp, photoshop, etc. you can make some really great menus. Mine was text marqueeing across the top of the screen, then some more on the bottom, then a message flashed up in the middle, after that the actual menu page showed up. Turned out really well, but took a long time to make.
