Is there a solution to the following quirk that I've been encountering in TMPGEnc when burning XVCDs. I'm setting the bit rate to 3000 kps and keeping the resolution to 352 x 240. After I finish enconding of one AVI file and load another one the resolution changes to 720 x 480. I then have to go back into to setting to change the resolution back to 352 x 240. If I'm not paying attention I'll burn the XVCD at the higher resolution which is incompatible with my standalone DVD player. Has anyone else experience this quirk? If so, are there any work arounds to it?
Results 1 to 1 of 1
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Streamclip Quirk?
By Lt. Dang in forum EditingReplies: 4Last Post: 1st Jan 2009, 09:08 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
TDA 3 Quirk
By pepegot1 in forum Authoring (DVD)Replies: 2Last Post: 8th Oct 2007, 10:37
