  1. Hi there
    Im using Smart Ripper / DVD2AVI / TMGPEnc / Nero
    My question is, how do I get the subtitles onto the vcd?
    thanks
    Athens, Hellas
    use input to virtualdub the pseudo avi from dvd2avi
    use in virtualdub the subtitle filter (vobsub)
    and frameserve to tmpeg
  3. Originally Posted by clickit
    Can you tell me more detail?? I am kinda new to DVD2AVI, and I want to make VCD with subtitle too. Thx
  4. hi anymore info appriciated.
  5. flaskmpeg also allows subtitles....
    you can frameserve from flaskmpeg into tmpgenc using avisynth
  6. Originally Posted by StoneRose
    once you've created your .d2v file...you load it into vfapi proggie that makes a .avi out of it.
    this .avi allows you to load it into vdub. using the vobsub filter in vdub, you can frameserve into tmpgenc (through vdub/vobsub) and get your subtitles.
    i have links...but not w/ me right now..i'll post when i can.
