Can someone tell me the order you have to convert the files. I have some downloaded. I don't understand. Do do i have to rip them then convert them. Can someone please list me a order on what way to do it.
Thanks,
Shawn
Ripping is when you want to copy vob files from your DVD to your hard drive so forget about it since your files are downloaded and, most likely, they are Mpeg or DivX (Avi) format. You need to encode (convert) your files to Mpeg1 (VCD standard) if you wanted to make VCD or Mpeg2 if you want SVCD. To encode AVI/Mpeg to VCD go here: http://www.vcdhelp.com/tmpgenc.htm (if you are encoding AVI to VCD then for perfect result go here http://www.vcdhelp.com/divxtovcd.htm#audio). To encode to SVCD go here: http://www.vcdhelp.com/tmpgencsvcd.htm 8)
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
out off order chapters
By vadded in forum Newbie / General discussionsReplies: 2Last Post: 16th Dec 2009, 13:11 -
DV - Frames out of order
By devonuto in forum EditingReplies: 3Last Post: 25th Jan 2008, 02:45 -
Field Order When Converting HD source to DVD
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jan 2008, 02:22 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14
