1. Can someone please explain "BIN/CUE" and what it does exactly.
2. If I would somehow come across a movie that someone had downloaded off the internet, could converting it to VCD or SVCD improve the quality of it?
a .bin is a binary image of a cd. the .cue is the file that lists the block size, and track info for the burning software. A .bin/.cue combo is burned to a blank cd by a program such as fireburner or cdrwin. The result is you have a CD that is identical to the original.
You'll never make a movie BETTER by converting it to VCD (mpeg-1) or SVCD (mpeg-2) because MPEG is a lossy compression codec. -
Dont quote me on this but:
1) Bin is a image file that is most commonly associated with CDRwin (cd burning software). All CD burning software has the ability to read date and create a single image file from it. The Cue I believe stores information about that bin, like header info, etc. The Cue is not always neccessary
2) No, Converting from one format to another does NOT improve quality to s certain degree. Basic rule of thumb is, you start with shit, you will end with shits. Now depending on framerate & other factors, it will play smoother in one form better than others, which would give the FALSEness(sp?) of appearing better. A crappy downloaded cam movie looks crappy no matter what format it is in.
Hope that helps
Simple VHS Capture Questions
By mostly_useless in forum Capturing and VCRReplies: 4Last Post: 29th Dec 2011, 17:00 -
Some Simple AviDemux Questions - iPhone video
By hech54 in forum Video ConversionReplies: 9Last Post: 27th Oct 2011, 10:45 -
Two simple questions, plz help!
By UnD3R0aTh in forum DVD RippingReplies: 40Last Post: 4th Mar 2010, 11:47 -
New to video making. I have a few simple (I hope) questions.
By BornRuffian in forum Newbie / General discussionsReplies: 1Last Post: 27th Apr 2009, 01:01 -
Some simple questions about Dreambox and HTPC
By Talayero in forum DVB / IPTVReplies: 0Last Post: 8th Apr 2009, 12:44
