I'm new to ripping VCDs so I hope u can help
In the "Advanced" tab in TMPG I am unsure what to put in the "Source Aspect ratio" box. I've read that I should use VGA(1:1) if it's gonna be played back on a PC and 4:3 625 line (PAL) if it will be played back on PAL TVs. I wanna make a mpeg1 where people can watch on a PC or burn to a CD if they want. I'm unsure which one to use. I'm new to this and I just wanna get it right.
thanks
If your input is an AVI file ( divx, xvid, whatever that play ok in MP ) use 1:1 for your input source aspect ratio. If you captured it off TV you ca set it to 4:3 and be confident it will work.
For DVD's that are native 16:9 you will have to ask someone else.
Aspect Ratio Help
By darkdream787 in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2011, 03:53 -
Aspect Ratio Looks Different After Encoding VHS Source
By jrodefeld in forum Video ConversionReplies: 1Last Post: 2nd Jul 2011, 10:35 -
Aspect Ratio
By ping182nz7 in forum EditingReplies: 12Last Post: 26th Apr 2010, 14:30 -
Aspect ratio
By ngc7088 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 11th Mar 2010, 12:25 -
Aspect Ratio's
By AndySpring in forum Newbie / General discussionsReplies: 7Last Post: 23rd May 2007, 13:55
