Ok, I know you're all going to tell me to go look in capture card review section, but there aren't always great reviews for all the cards (some aren't even covered). I want to know what people here are using, what problems people have had, and what's a good card for cheap. it seems like the older ones have driver problems. I currently have a STB gateway capture card which I don't like because of overlay and lack of capture options, plus I have to use their software. I want a capture card that's compatible with lots of software, and can capture standard resolution formats. I used to have an ati wonder (ISA) which I loved cause it was easy to use, lots of features.. But the ATI has pc resolution (320x200, 640x480). Will software allow me to change to different resolutions, or is that built in the card? Also, how do I bypass this 2meg file limit I hear about, and is it caused by the video card or windows? Basically, all I want to be able to do is capture at 352 x 480 at 25fps, with no driver problems or audio mis-syncing, and I don't want to pay that much.
Results 1 to 11 of 11
Get a Hauppage WinTV GO ( < 50 USD ) and a copy of VirtualDUB and you can do what you want at the resolutions you want. The 2 / 4 gig file size limit is a Windows / FAT thing but VirtualDUB can work around it with segmented captures.
Guest
get a win tv, its cheap and lots of people have used them. so if have any problems somebody is sure to help. There are a lot better cards about but it does the job.
nuff said
Daz -
I'm a fan of ATI All In Wonder RADEON.
I can capture really good MPEG-1 files in real time with MMC and capture great AVI's through VirtualDub.
it's also a very good video card - all my PC games run great on it
Very easy to use - with loads of in's and out's I'm very satisfied!
only drawback is that it's one of the more expensive capture cards
your pal,
Stinky -
Wow! Read the features of virtual dub!! Supports resolutions that my video capture card may not have a setting for.. that's cool. I played around with virtual dub to try to extract some divx movies so I could burn a VCD (couldn't get the audio to stop popping), guess I'll give it another try.
OK I have a simalar question what is the BEST the very BEST it money is NOT an issue I have been makeing some good money by taking peoples old home videos and converting them to S(VCD) with my Radeon however I know that there are better cards out there and I would like to give my customers the very BEST quality that I possable can
SO what do I need to get ?
We seem to like the cheap Cybermail card the compgeeks used to have.
The cybermail card is sold out (rumor is someone bought them all to sell on ebay). Any other:
non-tv
uncompressed
capture cards?
I don't need or want the TV features, just need to something that I can plug composite and s-video in, and use VDub. -
non-tv
uncompressed
capture cards?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
And how much are they selling for on eBay?
You can still order the Cybermail+Camera for $30 I think.
I ordered one last week, and they still havent shipped it.
I should have just went down there in person since its only a ~1 hour away
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
capture cards 360
By ihazcheezburga in forum Capturing and VCRReplies: 2Last Post: 19th Feb 2011, 20:14 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
Using 2 Hauppauge Capture Cards
By ddpool58 in forum Capturing and VCRReplies: 35Last Post: 21st Aug 2009, 22:53 -
Help with Video/Capture Cards.
By drsimp12 in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2007, 07:05
