Help
ive downloaded a few movies and cant get them to play or encode.The computer is asking for an XVID codec does anybody know where i can get it?.
Thanks in advance
Ok so ive found the nimo codec pac and installed it.Playing well no but cant open it with virtual dub or tempgnc to encode and burn it.
Can anybody help with this problem? -
I have found the Xvid codec in some of the mirc channels that host movies. Packetnews.com has a search function, type in xvid and you should be able to find it
I've found less frustration with going to Target & buying pre-encoded movies already mastered to DVD with nice cases for just a few dollars each.....
Panasonic DMR-ES45VS, keep those discs a burnin' -
i hear you. i rarely make any svcd's unless i'm ripping from dvd. too many problems with downloaded movies. ever sinse i got kazaa, my computer is littered with all kinds of codecs(no pun kitty). after they make a few conversions, they'll see that it better to rent a dvd and rip it or buy a premade movie. 3 to 14 hours to download, problems with codecs, audio and the like. 6 to 12 hours to encode. and then the the quality still might not be great.Originally Posted by kitty
my opinion-
download movies to watch without having to leave the house and only if they come out before dvd.
to make backups, use a dvd disk(98% redution of audio sync, video quality, and other problems.
but hey, it's good practice if you have nothing else to do. -
Right click the file select properties, second TAB should tell you all about the type of file it is.Originally Posted by maureen
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
Is there a codec for this
By jakefree in forum Video ConversionReplies: 0Last Post: 13th Jan 2009, 22:19 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
Which codec is the best?
By tuanvn.2007 in forum DVD RippingReplies: 3Last Post: 27th Sep 2008, 07:40
