I want to purchase a new DVD player. But I need to know whether the player will play CDR/CDRW/DVD-R/DVD-RW. I know there is the guide here that can look at, but I always seem to find somebody reporting problems with players even though the guide says otherwise.
I'm based in the UK, so you'll need to bear that in mind as not players are available here.
Thanks![]()
Indy
System Specs:
3.0 GHz Intel, 1 Gig RAM, WinXP, 2x40 Gig HD, ATI 64Meg Radeon VIVO, Sony DRU500A DVD-R -
-d -
I suggest using the DVD Players link here on vcdhelp.com. Put in your parameters and away you go. Most of the players have user comments that might help.
I purchased an APEX to play everything you listed. It's not fancy, but it works. The only thing it's missing is digital audio.
Good Luck.
Tivo Homer
what would the best setting for me for Handbrake ? plz answer
By FaisalKhan in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 08:38 -
SIMA Stabilizers -- The Definitive Thread
By Anonymous4 in forum RestorationReplies: 21Last Post: 8th Jun 2009, 20:27 -
Definitive command line for ffmpeg conversion to ipod from tivo?
By orev in forum Video ConversionReplies: 1Last Post: 16th Jan 2008, 13:29 -
The definitive guide to the total nube!
By stevezygote in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 16:02 -
Need someone who has seen Transformers The Movie(animated) to answer Q?
By Denvers Dawgs in forum Off topicReplies: 10Last Post: 27th Jun 2007, 20:42
