  1. I've two vcd, 1 40 minutes and 38 minutes second, I want to get mpeg from vcd join them and make a new vcd.
    I've tried to get the mpeg from vcd dat, and i got a 39:50 mpeg than it is 630 mb is it possible?
    Any idea will be wellcome.
    one topic is enough. if noone replies just reply to your own topic and it will be bumped to the top of the list.
    A 39.50 min vcd mpg/dat can't be 630 MB. It should be about 400 MB. Are you sure it is vcd?
  3. Could it be that the video bitrate was bumped up during the original encode? If I have a movie that needs to be split onto two disks, I'll bump up the video bitrate to fill the remaining space of the disk. If that is the case, it can be re-encoded to a lower video bitrate to fit on one disk.
  4. Sure about the size, How can I know the bitrate and recode it.
  5. I never tried this but I will be soon. Try it and let me know your results:
    http://www.tecoltd.com/bitratev.htm
    It's a bitrate viewer and it is listed here in the tools section.
    Jul 2001
    Novatix,
    I think I know what you're trying to accomplish. If I'm right, you have two VCDs, one is 40mins and the other 38mins. You want to join them and make one VCD out of it. Right? If so, then:
    - Copy the first VCD's .dat to your hard drive, rename it to vcd-1.mpg
    - Copy the second VCD's .dat to your hard drive, rename it to vcd-2.mpg
    - Use the Merge/Cut tool in TMPGenc's MPGEG Tools to select both of the new mpeg files.
    - Be sure to select 'MPEG-1 VCD Standard'
    - Pick a new file name for the joined VCD to output
    - Burn the new *.mpg using your favorite burning program to an 80min CDR and you're all set!!
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  7. I finally made it. But after joining the parts I tried to make chapters using easyvcd and the lenght isn't correct apearts just first part lenght, I joined parst using dvdtools.
    Any Idea?
