  1. simple q about batch encoding with TMPGEnc.......what is it? thanx.
  2. Member Treebeard's Avatar
    Aug 2002
    its setting up multiple files to convert at one after the other
    you set up like your going to hit start to convert but dont hit start select file--->save project.
    do this for 2 or 3 files.
    then select batch encode.
    you can select those 2 or 3 projects that you saved and it will run encoding on each one right after the other
    hope this helps
