My Abit KR7A-133 came with 2 USB (1.1) pin layouts on the mobo.
The one on the back of the machine come with a hookup for the plugs. The extra one is marked USB2. I wanted to get one of those adapters for front panel access. I tried one called Jet Panel but the plug they gave didn't fit on the mobo pins.
What have people used to connect to their extra USB connection?
The one on my mobo is layed out like this (top down view)
- X X X X
X X X X X
USB2 (stamped on mobo)
there's no pin where the '-' is marked.
The mobo doesn't mention where pin 1 is either.
thanks
Some USB connectors on motherboards come with 4 pins, some come with 5 pins. But the 4th and 5th pins are both ground lines and the other 3 pins are arranged the same way. You can generally use the same adapters for both. If your motherboard doesn't have the connector labeled you'll have to look in the manual to find which end is which.
Can a Laptop with an Esata port Hook up to an Internal Bluray Writer?
By jbitakis in forum DVD & Blu-ray WritersReplies: 2Last Post: 10th Nov 2011, 21:16 -
LG DV382 - USB Port
By Yabuike in forum DVD & Blu-ray PlayersReplies: 15Last Post: 6th Oct 2011, 08:41 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
USB port on DVP
By hootal in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2008, 09:35 -
USB Port Connection
By BillP2 in forum ComputerReplies: 19Last Post: 27th Sep 2007, 02:49
