  1. I've got the new Robocop Trilogy where disc 1 contains both the original theatrical realease + director's cut. I think it's called integrated branching. Anyway, when I rip with either DVD2SVCD, Smartripper, you-name-it, I can only rip the original version. Directors Cut is either missing the extra scenes or they are in the beginning of the movie! The only software that can handle this is DVDx which happens to be a very crappy program...
    How can I rip the vob-files to HD so I can use Avisynth as frameserver, without loosing the extra scenes or having them in the beginning of the movie?
    Johannes Clausen
  2. I've had the same problem with this Title.
    It's the authoring of the DVD, they did a shitty job and need to be shot.
    Haven't been able to rip it yet.
    DVD to VCD made eazy
    http://www.eazyvcd.tk
  3. You have to do it by hand unless someone out there knows how
    to rip the order sequence from the seamless branching.
    Rip the directors cut and then cut out all
    the stuff before the main title sequence and re-insert by the
    numbers. Be careful not to double up on the initial office shooting
    scene.
    luck!
