I'm in us, and where can i find some 99min CD-r, thanks. ^^
Try here:
http://yesbuy.net/9099mincdrsi.html
or
http://store.yahoo.com/runpc/cdraccessaries.html
Hope this helps
My GE-1101P and my Apex AD-1500 both read the CompUSA 99 min. CD-Rs just fine. It's the next best thing to a DVD burner (which I just bought!).
I'd rather have a bottle in front of me than a frontal lobotomy. -
Originally Posted by postul8or
You're actually more likely to have trouble writing 99-minute blanks. Many burners have firmware that won't write past a certain point, I've heard that 84 minutes is a common limit. Some burners also have trouble staying aligned in the spiral at the outer edge of the CD and can't successfully burn at higher speeds, but again most newer hardware should be able to handle that.
One interesting problem is that extracting data from a 99-minute CD sometimes doesn't work. I've heard that trying to rip a VCD burned past 95 minutes often fails, even though the VCD might play just fine. I've never tried, I've never burned more than about 90 minutes (3 30-minute shows). -
I've burned to 98 min.and every player(cd and dvd)I own recognize them.
According to this site:* Only the Lite-On/CyberDrive/AsusTek support 99min CDR media OFFICIALY! *
Are Solid State Drives Better?
By Gromit137 in forum ComputerReplies: 19Last Post: 2nd Jan 2010, 23:11 -
Seeking State-By-State List of DTV Stations with Sub-Channels
By Frank-0-Video in forum DVB / IPTVReplies: 2Last Post: 2nd Feb 2009, 17:07 -
Looking for a list of that will state which HD format TV networks use
By the_importer in forum DVB / IPTVReplies: 10Last Post: 21st Aug 2007, 13:42 -
New State Laws Target Used-CD Sellers
By rkr1958 in forum Newbie / General discussionsReplies: 28Last Post: 12th May 2007, 09:31
