I used to use dvdx 1.6 with dvddecrypter without any problems
until my pc crashed.
After a reformat and install win XP and dvdx 2.0
I now have problems
= Error message=
Mpeg2 Dec: Too much sample try other frame rate or change
detect/force 24 Hz flag
I tried changing the force24 option but no good.
I might go back to dvdx 1.6 if i knew where to get it.
or is win XP the problem.
any advice would be appreaciated. ????????????
Thanks.
Solved the too much sample error
changed the sound to AC3 6ch (08+80) ok now
Stll getting another error message but i dont think it has any effect
[color=red]=error message=
auth.dll: can't authenticate drive
disk may be locked[/color]. -
i have XP pro on my machine and had probs with DVDx 2 as well. E-mail me and I'll send you 1.6 if you have a fast connection. Personally, I think that 1.6 is the most stable and problem free of the DVDx line. Great stuff......it's almost the only thing I use
I got that a MPEG2dec: error failed to intialised tryed everything to fix couldnt figure it out Was trying to ripp blood in blood out. Kept giving me the error mesg I started looking at the case and noticed the ratio was 1:66:1 , so i thought that was a rather odd ratio so I changed discs and bingo it was the disk. The other error is normal I get that alot.
Thanks for the advice guys
As I said i'm still getting the disc locked message
but I just ignore it and it seams to stll work ok so i might stick with
dvdx 2.0 for awhile.
Thank again. -
I'd say this is probably an ASPI layer problem, but if you do your ripping from the DVD-ROM with DVD Decrypter, you're right, it makes no difference.color=red]=error message=
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 22:57 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 01:53 -
New DVDx InfoTool is out
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 22nd Dec 2007, 08:32 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 14:17 -
dvdx sync probs
By zookeeper525 in forum DVD RippingReplies: 0Last Post: 17th Aug 2007, 20:29
