Ok there is this site and it has all 21 eps of a show I like now I have only downloaded two so far, but you see when the download is done it is in a zip file then i unzip it and then i extract it and then the file is avi but when i play it there is no sound coming out of it?? Now I did find a way to get sound to it. I use the file with virtual dub and that adds the sounds but I found out that convert avi - avi makes the file bigger and I want to convert al these eps to mpg so i can watch them on my dvd player, but I also want to keep these eps on my computer and I need shorter files to fit 2 seasons so can anyone give me any tips.
Is there something i need to download to play the audio right after it finishs becuase if i run each file through Virtual dub it will only make it bigger. Help ASAP Please
Results 1 to 1 of 1
Need to buy a suitable PCI X firewire card for my newish PC ASAP
By Canon GL-2 Guy in forum ComputerReplies: 2Last Post: 5th Sep 2011, 00:08 -
HELP! ASAP! Conversion .VOB to .AVI videos are jumpy!
By AngelVideo in forum Video ConversionReplies: 4Last Post: 20th May 2011, 19:36 -
Windows Movie Help ASAP
By OTH in forum EditingReplies: 2Last Post: 28th Feb 2008, 07:42 -
Guides needed asap
By demonwarrior in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2007, 08:35
