OK I will give a rundown of what my entire problem is.
I need to convert about 2,000 .jpg images over to a vcd using about 20 different menus for them.Each of my menus are mpeg files.Now before I have used DVD Picture show...but I cant use motion video for menus with it. I downloaded DVD Workshop but I am having trouble using it and getting what I want to do with it...it always tells me I cant add more than 10 images when adding my pics.
Anyone know any simple program I can simply convert my images into .mpg's alone and then use DVD Workshop to throw in my menus with.It would be much simpler if DVD Picture show didnt make them directly into a VCD,then I could have a mpeg. to work with from it.
I need help with the best and easiest solution to my delima.
One other thing....Is there any software out there that will allow me to use flash intro's as my menus...I had to take mine and convert to .avi then convert to .mpg .... which made me loose some quality.....if I could just use flash for the menus it would be better.
Thanks for any and all help from anyone in advance
Results 1 to 1 of 1
Blending Images(jpg) together
By Soixante in forum EditingReplies: 11Last Post: 24th Jan 2011, 19:28 -
converting bunch of images with sound to video
By dsikorsky in forum Video ConversionReplies: 0Last Post: 10th Aug 2009, 16:34 -
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 29th Nov 2008, 16:13 -
converting JPG images to VIDEO / MOVIE
By pglenn in forum Video ConversionReplies: 4Last Post: 18th Apr 2008, 01:03 -
How do I join JPG images to creat an AVI file
By forensic in forum EditingReplies: 9Last Post: 15th Mar 2008, 22:23
