im used dvd decryptor to rip a dvd to my HDD. when i try and open it up with DVDx... it gives me this error: NO Corresponding VOB file found!
please help
Results 1 to 9 of 9
I used the same programs before
I think in dvdx you have to open the ifo file
not the vob file. -
Why are you ripping the dvd ?
I have found it doesn't really increase the processing speed.
dlb. -
its always better to rip it the harddrive as this little proggy uses your dvd drive constantly which may in turn kill the drive after a while!!! constant spinning for hours cant be good!! Anyway this prog uses the ifo file on the main vob set.
dvddecrytor to take to the dive
then use dvdx & open the ifo!!
Why R U using this program anyway as the quality is really manky compaired to tmpeg????
Kev!
ps with regard to DLB.. it does infact cut the time down as its not dragging the vobset to the drive as its already there -
Hey I'm sorry P@iNKilleR, but my machine will process a film i.e Swordfish in 1 hour 47 mins. DVDx will process at around 23 frames per second, just under real time playing. Even tweaking the setting to the higher quality vcd the film is processed in just over 2 hours (18 frames per second)
I admit there are some pieces of blockiness but it is very acceptable. I tried using your method and the process time was going to be around 8 hours, far too long for me.
dlb. -
sorry dlb if I sounded a bit tetchy m8 I didnt mean to honest was just stating what happened on my pc.... anyway that time is quite amazing!!!! even for dvdx
anyway if I offended U m8 I'm sorry was just trying to help the author of the post but I'm really interest in what machine U have to do that time though??
Kev! -
so wat program can i use to encode the dvd after dvd decrypter which allows subtitles?
Hi again,
no offence taken.
I have a HP model 781 uk.
Intel P4 2.0 ghz processor 256 mb ram.
dlb.
ps - I have also tried easyvcd last night and the results are about the same as dvdx, but takes longer and I had problems getting the correct audio. The program kept crashing.
DVDX in my humble opinion is still the easiest and the best for the novice. -
Originally Posted by P@iNKilleR
dvdX encodings are far worse than of eg. TMPGenc.... Let dvdX frameserve and let tmpgenc do the encoding, with or without subtitles, the quality is FAR better!!
btw: do NOT use rgb24 in dvdX, use rgb32 instead.... the image is more like the source and not overlighted etc.
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 22:57 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 01:53 -
New DVDx InfoTool is out
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 22nd Dec 2007, 08:32 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 14:17 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
