I have been ripping dvds for a while but thought I'd try a different approach to get better quality rips. I was following Pinoys2210's DVD Ripping Guide v 2.3 and everything was going fine until I had to use VOB2Audio. After I select the .lst file, the guide says a ms-dos window should pop up for about 3 minutes, but mine does that for less than a second, and as a result I have no options to choose from in the audio stream window. I was hoping maybe somebody could shed some light on this. Another point, the link to SSRC is broken, so I can't obtain it, and the toolame isn't on dooms site, but just lame is. Will this work the same? Help!
Results 1 to 1 of 1
DVD Ripping problems with cucusoft
By oki4life in forum DVD RippingReplies: 1Last Post: 27th Nov 2011, 17:44 -
Audio problems after ripping DVD
By ksimz202 in forum Newbie / General discussionsReplies: 3Last Post: 28th Mar 2011, 01:49 -
Problems ripping my DVD
By KayAt in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2009, 16:33 -
audio sync problems after ripping dvd
By blubot in forum Video ConversionReplies: 4Last Post: 23rd Sep 2008, 10:14
