Help Plz... Can't open some AVI movies on Virtualdub!!and their ok!
I believe i have all the codecs... I've tried ACE mega pack and Nimo Pack
Thx for the support....
Rui Fragoso
You should supply a little more information, like any errors you received.
Can you play your AVI in Windows Media Player?Impossible to see the future is. The Dark Side clouds everything... -
Not the sameOriginally Posted by felpet
Playing and editing may use different codec's. Try to load into Vdub and select file > file info
Or right click the file and select properties, this should tell you if you have a codec missing.
Vdub > full processing mode
Video > compression > codec list -
Go to VdubOriginally Posted by Greenie
This shows what you have, do you have DivX 5 ?
What does it list in there ? something is missing !
Do the same for Audio
I'm trying to open .WebM in VirtualDub
By alinhoalisson in forum Video ConversionReplies: 25Last Post: 22nd Sep 2014, 05:20 -
Open h.264 in VirtualDub
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 6th Nov 2011, 20:21 -
How to open WMVA with VirtualDub?
By Zeokat in forum Newbie / General discussionsReplies: 5Last Post: 24th Oct 2011, 03:47 -
can't open flv in VirtualDub
By shun in forum Video ConversionReplies: 3Last Post: 26th Jul 2010, 18:10 -
Virtualdub can not open xvid
By quxote in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2009, 00:11
and their ok!
