Hi everyone...
I'm getting sync loose if I capture with PicVideo MJPEG codec in any program. When I try other codec or uncompressed I don't have any problem... Any idea to solve it???
Thanks in advance
Results 1 to 10 of 10
Originally Posted by hardrock
Does the video go gradually out of sync or is it out by the same amount throughout?
I capture with MJPEG regularly and occasionally get captures out of sync. Whilst the file is still an avi it is usually repairable. -
Could be the quality of your VHS which cause the capture to decay out of sync. How was the quality of the VHS, did it have any drop outs, or tracking problems on the VHS you tried to capture.
Audio sync? Where? VirtualDub?
I don't use VirtualDub to capture, I use iuVCR...
Convert 4:3 PICVideo mjpeg to 16:9 DV w/o losing clarity
By brassplyer in forum EditingReplies: 12Last Post: 5th Jan 2011, 01:13 -
Convert H264 to AVI (PicVideo codec)
By dandaka in forum Video ConversionReplies: 2Last Post: 3rd Nov 2010, 03:15 -
Anybody used FFDshow Mjpeg codec for capture?
By davexnet in forum Capturing and VCRReplies: 8Last Post: 31st Oct 2010, 00:27 -
Low compression codec, other than MJPEG.
By blitter2 in forum Capturing and VCRReplies: 4Last Post: 2nd Dec 2008, 18:20 -
Ricoh Caplio R5 MJPEG and Video Studio codec query
By Pronto71 in forum Video ConversionReplies: 1Last Post: 19th May 2007, 21:30
