it was working fine before. i forgot how i got it to work after i installed jaguar. has anyone got it to work? and how?
Results 1 to 10 of 10
I installed the encoder after I installed Jaguar. It works fine for me. I just choose File->Export->Movie to MPEG2. What "trick" do you have to do?
i forgot how to install it...it's just a component. how did you do it? i remember last time all i did was put it in my quicktime folder. but that doesnt work.
Oh, you just have the actual component file. Mine gets installed by installing DVD Studio Pro. To install the component file by hand, I hear you have to be logged in as root before trying to copy that file.
I am also having trouble getting mpeg 2 encoder to work. Can someone explain to me? I have it in on my desktop but when I click on it says choose application, and mpeg 2 doesnt show up on the quicktime player export menu. I am a newbie to macs(running jaguar) and dont know much about component files or logged in as root.
Thanks -
Did you install QT Pro first?
I had a similar problem, and found somewhere in FCP literature that QT Pro needs to be installed first (before FCP or DVDSPro — I guess because these applications are so dependent on QT) I would suggest erasing/uninstalling all affected programs. Then, update to Quicktime Pro 6, Install FCP, then DVDSPro.
If you didn't do a "clean" install or archive and install for 10.2, that might be the problem as well. I just "updated" my system, and had applications crash like Value Jet that were rock solid previously. The "archive and install" option under the 10.2 install might be worth a try — I've read elsewhere of people having similar problems.
Also, I'm pretty sure that you encode mpeg2 from Quicktime. After I installed DVDSPro, "Export as Mpeg2" became an option (it wasn't there previous to installing DVDSPro). Good luck. -
First of all: Proceed at your own risk!.
1. You need QT pro.
2. Log into your mac as root.
3. Copy the export component file to /System/Library/QuickTime/
For info on how to enable the root user go here:
http://docs.info.apple.com/article.html?artnum=106290&SaveKCWindowURL=http%3A %2F%2Fkbase.info.apple.com%2Fcgi-bin%2FWebObjects%2Fkbase.woa%2Fwa%2FSaveKCToHomePa ge&searchMode=Expert&kbhost=kbase.info.apple.com&s howButton=false&randomValue=100&showSurvey=false&s essionID=anonymous|154776356 -
Oh, and after enabling the root user I suggest you disable it after doing what you need to do. That account has full system privileges (admin does not). That account allows you to delete/move/change stuff that you normally cannot do. If you were to goof something up while using that account, you could mess up your system and end up having to reinstall the OS.
Thanks for the help guys.
But it still doesnt work. I enable root and logged in as root. I copied the mgeg compent file system/library/quicktime and still no dice. So I tried copying it into several other qt folders and that didnt do anything either.
I downloaded fcp v.1 but I cant install it because it says that it isnt supported by classic...
Is there anything else I can do?
What would be the best free MPEG2 encoder?
By CursedLemon in forum Video ConversionReplies: 12Last Post: 20th Sep 2010, 22:10 -
Which mpeg2 encoder library?
By julesh in forum ProgrammingReplies: 0Last Post: 18th Feb 2008, 15:04 -
Capture Cards that work with Media Encoder 9.0
By alec_owen in forum Capturing and VCRReplies: 1Last Post: 8th Jan 2008, 07:26 -
DV to MPEG2 using Mpeg encoder
By neftv in forum Video ConversionReplies: 8Last Post: 16th Jul 2007, 06:39 -
best free mpeg2 encoder for me!!!
By malahal in forum Video ConversionReplies: 10Last Post: 9th May 2007, 12:18
