Can anyone please help. I am converting divx movies to mpeg2 with virtual dub and tmpge. I then burn to dvdr with ulead dvd movie factory. These play fine in stand alone dvd players but when I play them on playstation 2 there is sound but no picture.
Does anyone have any ideas?
Burn Baby Burn
I don't think you can play any SVCD or VCDs on PS2.
Read this... http://www.vcdhelp.com/faq.htm#ps2playlater,
alirio -
But I'm not encoding to svcd or vcd. I encode to mpeg2 on dvdr media. Also the fact that Playstation 2 can play the sound surely means it recognises the disc. I have read that there should not be a problem, so I figure I'm doing something wrong. Help, I am still very new to all this.
Burn Baby Burn -
I use TMPGEnc using the DVD template to encode vcd and svcd's to mpeg2. Then use DVD Complete to create menus and extras and tell it to create a dvd-image. Then I use Prassi PrimoDVD to test and burn. Doing all this makes the dvd work on almost every standalone dvd player and it also works on Playstation 2 and Xbox without mod chips.
ok well all this is new to me because everywhere I read PS2 doesn't play 'em...I have one question though do you really need DVD Complete to make it work? If so where can I download this at...thanks!
later,
alirio -
I have one of the newer Playstation 2's and it reads dvd-r's just fine. My friend has one of the first Playstation 2's and it won't read dvd-r's. Maybe different chipset or something in it that makes it read it....Don't look on a website for DVD Complete. I have done like 2 dvd-r's with DVDit PE and they work on mine. I don't think it matters what you author it with, as long as you get the ifo's correct.
well since I don't have a dvd burner (sucks!) is it possible to convert avi, mpeg-1 or mpeg-2 files into ifo's? and then burn on nero? just curious...
later,
alirio -
You need a dvd-burner......maybe a modchip might help play cd-r's....With the dvd-r's i can get 2 movies on one disc. Don't think there's any way for vob and ifo files on cdr. Sorry couldn't help anymore.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
